Home
Introduction
What train set to buy
Cost
Basic Tools
Base Board
Railway Track
Kato Track
Track Conversion
Building a Layout
Layout Designs
Members Layouts
Electronics
Digital Control (DCC)
Electronic Projects
Scenery
Plastic Kits
Rolling Stock
Maintenance
Model Railway Spares
Service Sheets
Harry Potter
Thomas Tank Engine
7mm Narrow Gauge
Railway Software
Downloads
Photo Gallery
FAQ
Forums
Railway Dictionary
Competitions
Links / Sponsors
Terms & Conditions
Privacy Policy
Contacts
Scenery
Airbrushing
Ballast
Bridges
Buildings
Building Lighting
Grass
Hills
Inclines
Paint Conversion
Rock Faces
Hornby Skaledale
Railway Stations
Trees
Tarmac
Tunnels
Viaduct
Water
Finishing Touches
Electronic Projects
Railway Crossing
Building A Signal
Street Lights
Rolling Stock
Bachmann Wagons
Hornby Locomotives
Hornby Carriages
Hornby Wagons
Lima Locomotives
Lima Wagons
Loco Modification
Wagon Modification
Hornby Range Lists
Hornby Range 2006
Hornby Range 2007
Hornby Range 2008
Hornby Range 2009
Hornby Range 2010
Hornby Range 2011
Hornby Range 2012
Hornby Range 2013
Hornby Range 2014
Hornby Range 2015
Hornby Range 2016
Hornby Range 2017
Hornby Range 2018
Hornby Range 2019
Hornby Range 2020
Hornby Range 2021
Hornby Range 2022
Hornby Range 2023
Hornby Range 2024
Hornby Range 2025
Hornby Model Railway Locomotive Reviews -  J83
Not Recommended - It is not recommended you purchase this model unless there is no other option. These models have major limitations and are lacking in even the most basic mechanical or detailing features. For a railway model to be "Not Recommended" a model must score 3 or less.  Hornby J83. (R2164U)  Rating 3/10
The Holmes-designed J83 was delivered to the North British Railway in 1901 and all forty of the class entered LNER service, with thirty-nine making it to British Rail ownership before the last of the class was withdrawn in 1962. The class was famously hard-working, with only three locomotives failing to manage a million miles and one, No. 9830, amassing two million.
Given the impressive nature of the prototype, it is disappointing to be so underwhelmed by the model. I will, as a result, be awarding this model 3/10 – it is even less accurate a model than the 4/10-awarded ‘Smokey Joe’ pug. However, there is an excellent reason why it is not 0/10, and I will explain it shortly.
But first, the detractions. This model bears a passing resemblance to the prototype, but there is little if anything that has been accurately reproduced. It is too tall and the wheels are too large. This is because it uses Hornby’s standard 0-6-0 pannier tank chassis (albeit without traction tyres), with all its attendant problems – poor electrical pick-up, tendency to stall at low speeds, bizarre gearing giving a hell-for-leather top speed (I know of someone who has a J83 that will go faster than his HST!), and difficulty traversing insulfrog points. This last criticism is particularly pointed, as in real life this locomotive served as a shunter, and one would presumably use the model for this purpose on one’s layout.
The livery is basic to the point where I wonder if it is painted at all – it certainly has the look of pre-coloured plastic. Having said that, the lining out of the side panels is done to Hornby’s usual high standard. This example is weathered, which also serves to disguise some of the grosser flaws with the chassis detailing (or lack thereof).
The bodywork detailing is minimal to non-existent. There are no fitted wire handrails, representations instead being moulded in the plastic bodyshell (reminiscent of some of the worst aspects of Hornby Triang models, I’m afraid), and there is neither detailing in the cab nor glass in the crude cab windows. Couplings are of the large Lima ‘D-ring’ type, and the buffers are not sprung, although the rivet-work on the buffer-beam seems well done. Finally, the RRP on one of these is laughably optimistic. No one in their right mind would spend £45 on one.
Having said all of that, I shall now explain why this model is awarded 3 marks. It earns them for being absolutely brilliant at one thing. This is the perfect model for children who feel themselves too old for Thomas the Tank Engine (at, say, 8 years old) and who want something more like a ‘grown-up train’. There is virtually nothing on the body of this locomotive that will get broken off by impatient little hands, and the warp-factor top speed gives the model quite a lot of play value. It is available as part of the ‘Old Smokey’ trainset, where it comes with two antiquated LNER clerestory coaches, manufactured with equally antediluvian tooling. Again, the play value of the set is high, even if its historical accuracy leaves a lot to be desired.
As I said, no one with even a modicum of sense would buy one for the same price as a Bachmann pannier tank or prairie, but they frequently crop up online separated from the ‘Old Smokey’ set at about £20 each (and with the reference number R2164U). This, I submit, is a far more reasonable price for a locomotive of ‘Railroad’ quality – although even the Railroad Jinty has fitted wire handrails. This is a model to be played with, and even with its many fearsome imperfections mine looks well enough as it rattles happily round my mainline with ten or so coal wagons.
Overall Rating: 3/10
[back to the top]
Diesel and Electric Review List
Hornby Model Railway Class 06 Review - BR Blue, Liveries Hornby Model Railway Class 08 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue, Liveries Hornby Model Railway Class 09 Review - EWS, Loadhaul, Mainline, Trainload, Br Blue Liveries Hornby Model Railway Class 31 Review - BR Blue, Liveries Hornby Model Railway Class 37 Review - EWS, Loadhaul, Mainline, Trainload, BR Blue, Liveries Hornby Model Railway Class 47 Review - Virgin, BR, Liveries Hornby Model Railway Class 50 Review - NSE, BR, Liveries Hornby Model Railway Class 56 Review - Loadhaul, EWS, TrainLoad, BR, Transrail Liveries Hornby Model Railway Class 58 Review - EWS, Loadhaul, Mainline, Trainload, Transrail Liveries Hornby Model Railway Class 60 Review - EWS, Loadhaul, Mainline, Trainload, Liveries Hornby Model Railway Class 66 Review - EWS, GBrf Liveries Hornby Model Railway Class 67 Review - EWS, Royal train Hornby Model Railway Class 90 Review - EWS, Loadhaul, Mainline, Trainload, Transrail, Intercity, Liveries Hornby Model Railway Class 92 Review - EWS, Transrail, Liveries Hornby Model Railway Class 121 "Bubble Car" Review -  BR Blue, BR Green, Network Southest NSE Liveries Hornby Model Railway Class 142 Pacer Review Hornby Model Railway Class 153 Review - Central trains, Arriva, Reginal Railways Hornby Model Railway Class 390 Virgin Pendolino Review - Virgin Liveries Hornby Model Railway Class 373  Review - Eurostar, GNER White rose Liveries
Steam Locomotive Review List
Hornby Model Railway Class 0F 0-4-0ST  Review - BR, Smokey Joe liveries Hornby Model Railway Class A4  Review - LNER, Mallard, Silver Jubilee, South Africa, Sir Nigel Gresley Hornby Model Railway Class N15 'Ling Arthur' Review - SRHornby Model Railway Class Princess Royal Class Review Hornby Model Railway Pannier Tank  Review - GWR, Great Western Railway Hornby Drummond T9 'Greyhound'Hornby J83
Thomas The Tank Engine And Friends
Hornby Model Railway Thomas The Tank engine And Friends, Annie and Clarabel  Review Hornby Model Railway Thomas The Tank Engine And Friends - Percy and 2 Troublesome Trucks Review Hornby Model Railway Thomas The Tank Engine And Friends - Toby and 3 Trucks Review
Hornby Model Shop
R1255 -
Price: £
Price: £
Hornby Trakmat
Hornby Extension Track Pack A
Price: £
Hornby Extension Track Pack B
Price: £
Hornby Extension Track Pack C
Price: £
Hornby Extension Track Pack D
Price: £
Hornby Extension Track Pack E
Price: £
Hornby Extension Track Pack F
Price: £
Hornby Trakmat
